Secure Control Messages
Configure Message Digest (MD) 5 authentication to secure control messages on the TCP connection between MSDP peers.
  1. Enter either Global Configuration mode or VRF Router Configuration mode for a specific VRF context:
    enable
    configure terminal
    Optional: router vrf WORD<1-16>
  2. Enable MD5 authentication:
    ip msdp md5-authentication {A.B.C.D} [enable]
  3. Specify the case sensitive password for MD5 authentication:
    ip msdp password peer {A.B.C.D} WORD<1-80>
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#ip msdp md5–authentication 21.0.0.2 enable
Switch:1(config)#ip msdp password peer 21.0.0.2 helloworld
Variable definitions
The following table defines parameters for the ip msdp command.
Variable
Value
{A.B.C.D}
Specifies the MSDP peer IP address.
WORD<1-80>
Specifies the MD5 authentication password.
